[GRASSLIST:3979] Re: [GRASS5] [bug #2545] (grass) vect32 fails
to build
Paul Kelly
paul-grass at stjohnspoint.co.uk
Thu Jul 22 14:39:05 EDT 2004
On Wed, 21 Jul 2004, Lorenzo Moretti wrote:
>> The patch below shows how I propose to fix this. I think src/CMD/gmake.sh
>> should be changed so that $(OBJARCH) is preprended at the beginning of a
>> path leading to a .o file rather than immediately preceding the filename.
>> i.e. Vlib/open.o becomes $(OBJARCH)/Vlib/open.o rather than
>> Vlib/$(OBJARCH)/open.o as at present.
> Paul
> Your patch resolve bug #2545 and bug #2547. Now is possible to create
> libvect_combined.a
OK- I have committed it.
>> This should fix things for both the alternate and gmake systems.
>> It will also cause problems for badly written or non-standard Gmakefiles.
>> The only one I came across is for r3.null and I will fix that by building
>> r3.null and r3.mask from the same directory (cf. r.mapcalc and r3.mapcalc
>> are built from the same directory).
>> But there might also be problems with non-standard Gmakefiles in add-on
>> modules people have written themselves I suppose. But probably not very
>> likely. So I just wanted to post this here for a while for comments before
>> committing the changes.
>> The r.terraflow Gmakefile also needs fixed so it will work with both build
>> systems. It has a related but different problem with using
>> sub-directories.
> Yes the only problem is in r3.null like you say...
I changed it yesterday.
r.terraflow's Gmakefile still needs fixed to work with the alternate build
system.
