[GRASS5] Re: [GRASSLIST:3536] Re: script for importing Terra-ASTER data
Michael Barton
michael.barton at asu.edu
Tue Jun 1 16:35:30 EDT 2004
Zbigniew,
I updated the r.in.aster script to read Level 1A ASTER imagery. I have
a set and have tested it. It seems to work fine. I include a copy here.
I am also posting it on my website in a new GRASS script exchange that
I am going to launch (with some trepidation) in a followup posting.
Thanks for your help in testing this.
Michael Barton
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040601/6cf6e5f7/r.in.aster.tar.gz
______________________________
Michael Barton, Professor & Curator
School of Human Origins, Cultures, & Societies
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
On May 28, 2004, at 2:23 PM, Zbigniew Perski wrote:
> Dear Paul,
> As I did, you are trying to georeference subdataset 1. This is NOT
> image band 1. This is the metadata and GCP's for image bands 1-3 VNIR.
> So, now I understand my frustrations!
> To actually georeference image band 1, you need to indicate
> subdataset 2. The relationship between images and subdatasets is
> listed at the bottom of the output to gdal-info. In brief, it is
>> band 1=subdataset 2, 2=3, 3n=4, 3b=5, 4=8, 5=9, 6=10, 7=11, 8=12,
>> 9=13, 10=16, 11=17, 12=18, 13=19, 14=20. Subdatasets 1, 5, 6, 7, 14,
>> and 15 are reserved for metadata and GCP's.
> OK.
>> If Level 1A can be georeferenced, I can easily make the change to the
>> script to let you select them via a flag.
> This I think will be helpfull for many people since L1A data are more
> frequent in ASTER database (as I remember 2 years ago L1B was realy
> rare.).
>> Also, I suspect that MODIS images work much the same way as they
>> come from the same organizations and use the same hdf format. If so
>> and someone could send me the output of gdal-info for a MODIS image,
> For MODIS not, but for ASTER 1A I can send you some outputs in monday
> if you wisch. I Have not MODIS data in this moment.
>> I could try to either include MODIS in an expanded r.in.aster or
>> make a companion r.in.modis.
> It will be great too I think!
> Many thanks
> Zbigniew
