[GRASS5] [bug #2462] (grass) I cannnot perform the installation
Wolfgang Lueck wolfluck at mweb.co.za
Mon Jun 7 19:42:23 EDT 2004
This is not a bug. Read the installation instructions carefully.
You have to specify the location of your dependent libraries such as.
./configure --with-postgres-includes='/usr/include/pgsql' --without-odbc
--with-motif --with-gdal=/usr/local/bin/gdal-config
Greetings Wolfgang
> Message: 1
> Reply-To: Request Tracker <grass-bugs at intevation.de>
> From: Request Tracker <grass-bugs at intevation.de>
> To: grass5 at grass.itc.it
> Cc:
> Date: Mon,  7 Jun 2004 11:26:56 +0200 (CEST)
> Subject: [GRASS5] [bug #2462] (grass) I cannnot perform the installation
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2462
> Subject: I cannnot perform the installation
> Platform: GNU/Linux/i386
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> GRASS Version: 5.3
> I cannot finish the installation of GRASS 5.0.3 source code, after doing "./configure"
> checking whether to use PostgreSQL... yes
> checking for location of PostgreSQL includes...
> checking for libpq-fe.h... no
> Nevertheless. libpg-fe.h is correctly located under /usr/include/pgsql
> Thank you!
> -------------------------------------------- Managed by Request Tracker
> --__--__--
> grass5 mailing list
> http://grass.itc.it/mailman/listinfo/grass5
> End of grass5 Digest
