[GRASS5] i.fft segemntation fault
Glynn Clements
glynn.clements at virgin.net
Tue Jun 8 23:58:27 EDT 2004
Otto Dassau wrote:
> I tried to use i.fft in GRASS 5.3 (CVS) but only get errors like:
> a) Starting FFT...
> fftw: BUG in executor: invalid plan
> b) Starting FFT...
> Speicherzugriffsfehler (segmentation fault)
> Does this module work at all?
Yes.
> Is there a special way to use it?
No.
> I installed fftw RPMs. Is this version broken?
> fftw-2.1.3-1102 ?
> fftw-devel-2.1.3-1102 ?
Maybe. The code which actually uses FFTW is:
plan = fftw2d_create_plan(
dimc, dimr,
(i_sign < 0) ? FFTW_FORWARD : FFTW_BACKWARD,
FFTW_ESTIMATE | FFTW_IN_PLACE);
fftwnd_one(plan, data, data);
fftwnd_destroy_plan(plan);
Examining the source code of FFTW 2.1.3 indicates that the above error
message always corresponds to an invalid plan type. According to the
documentation, fftw2d_create_plan() will always return either a valid
plan or NULL (and NULL would result in a segfault).
Glynn Clements <glynn.clements at virgin.net>
