[GRASS5] Re: [GRASSLIST:3661] Re: moving window bigger than 25 cells
Tue Jun 15 03:56:26 EDT 2004
> > I need to calculate max, min and mean values within a moving window with
> > a window size bigger than 25 cells (which is the upper limit for
> > r.neighbors). Does anybod know some advice?
> If you have the source code, delete the following line:
> 	parm.size->options    = "1,3,5,7,9,11,13,15,17,19,21,23,25" ;
> from src/raster/r.neighbors/cmd/main.c, then re-compile and
> re-install.
is this better?
