[GRASS5] Grass newbies in dire straits
Michael Barton michael.barton at asu.edu
Mon Jun 28 10:28:46 EDT 2004
It's not exactly clear what you want to do. However, take a look at my
d.out.png script. It is distributed with GRASS 5.3 and 5.7 and can also
be found on my website <www.public.asu.edu/~cmbarton/grass.htm>
It allows you to output a raster PNG image of the current display
monitor at single, double, and quad resolution. If you want to set the
monitor to a specific size prior to this, use d.monsize.
____________________
C. Michael Barton, Professor
School of Human Origins, Cultures, & Societies
PO Box 872402
Arizona State University
Tempe, AZ  85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
On Jun 28, 2004, at 3:01 AM, grass5-request at grass.itc.it wrote:
> From: Prabhath Sirisena <prabhath at vesess.com>
> Date: June 27, 2004 3:48:20 AM MST
> To: grass5 at grass.itc.it
> Subject: [GRASS5] Grass newbies in dire straits
> We are using GRASS 5.0.3.
> How can we dynamically extract an image of
> specified size from a vector map (we have
> an Autocad DXF)within GRASS? Any raster image
> format would do.
> This needs to be done through a programming
> language (possibly Java or C) as GRASS will
> be on the server side in the client/server
> application we are developing.
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040628/a68c9835/attachment.bin
