[GRASS5] db.execute and min() max()-SQL-functions
Stephan Holl
sholl at gmx.net
Tue Jun 29 12:41:11 EDT 2004
Dear developers,
I am trying to figure out my min and max-values of my attribute-date
stored in PG.
steph at kermit:~ > echo "SELECT min(categorie), max(categorie) FROM
tk25_9_poly;"|db.execute
DBMI-Postgres driver error:
Cannot execute:
SELECT min(categorie), max(categorie) FROM tk25_9_poly
WARNING: Error while executing: "SELECT min(categorie), max(categorie)
FROM tk25_9_poly"
Is this not (yet) supported or something else wrong?!
Using psql the same syntax works.
Can somebody point me to the right direction?
Thank you
Stephan Holl
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040629/8251bbf4/attachment.bin
