[GRASS5] Re: [Gdal-dev] ERDAS/IMG driver error for NULL values
Markus Neteler neteler at itc.it
Wed Jun 30 09:02:55 EDT 2004
On Wed, Jun 30, 2004 at 11:14:45AM +0100, Paul Kelly wrote:
> Hello Otto
> Otto Dassau wrote:
> > Also there is no coordinate system specified.
Otto, are you using the original GRASS driver or the new driver
of Radim Blazek (not in CVS yet)?
> This should be:
> > > datum: potsdam
> > > towgs84: 590.5,69.5,411.6,-0.796,-0.052,-3.601,8.30
> > > proj: tmerc
> > > ellps: bessel
> > > a: 6377397.1550000003
> > > es: 0.0066743722
> > > f: 299.1528128000
> > > lat_0: 0.0000000000
> > > lon_0: 9.0000000000
> > > k_0: 1.0000000000
> > > x_0: 3500000.0000000000
> > > y_0: 0.0000000000
> This looks like a deficiency in the r.out.gdal script.
I don't think so. Because the r.out.gdal script is simply a wrapper
around gdal_translate.
In fact gdalinfo doesn't print the projection:
gdalinfo ~/grassdata/spearfish57/PERMANENT/cellhd/elevation.dem | head
Driver: GRASS/GRASS Database Rasters
Size is 633, 466
Coordinate System is `'
Origin = (590010.000000,4928000.000000)
Pixel Size = (30.00000000,-30.00000000)
Corner Coordinates:
Upper Left  (  590010.000, 4928000.000)
Lower Left  (  590010.000, 4914020.000)
Upper Right (  609000.000, 4928000.000)
Lower Right (  609000.000, 4914020.000)
I am using the new driver which contains the relevant code (I'm no
expert). Somewhere this info get's lost. Or should the driver make
use of the new GRASS 5.7 projection functions (such as GPJ_grass_to_wkt
in grass57/lib/proj/convert.c )?
Once solved in GDAL also r.out.gdal will write out the projection.
Markus
