[GRASS5] WinGRASS questions on NVIZ and GRASS 5.3
Richard Greenwood
rich at greenwoodmap.com
Tue Mar 2 23:45:05 EST 2004
Glynn Clements wrote:
> If it doesn't become available on grass.itc.it tomorrow, I'll email
> you a copy (even stripped and bzip'd, it's around 700kb, as Tcl/Tk is
> statically linked).
Thanks Glynn. The size should not be a problem for my incoming SMTP. I
do not know whether my ability, or inability, to run your binary would
tell us much, but I would still be interested in trying. A month or so
ago you listed the versions of Cygwin, XFree, gcc, etc. that you had
used to successfully build and execute NVIZ, all of which were older
than I had. I "downgraded" gcc and a couple other things, but I was
still not not able to execute any version of NVIZ that I had compiled. I
was not able to find older versions of XFree. Cygwin is a hell of a lot
easier to "upgrade" than to "downgraded", and I really do not know if my
problems are version related or elsewhere.
Thanks again,
Rich
Richard Greenwood
www.greenwoodmap.com
