[GRASS5] [bug #2349] (grass) nviz in 5.0.3 fails to start if Spearfish erode.index is drape image
Request Tracker
grass-bugs at intevation.de
Fri Mar 5 11:40:45 EST 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2349
Subject: nviz in 5.0.3 fails to start if Spearfish erode.index is drape image
I just tried to answer Markus' call for a new binary build of 5.0.3 on Linux,
and in testing it ran into a problem. I happened to pick erode.index as the
raster file to display on top of the DEM (all from Spearfish), and nviz dumped
with the errors pasted below. Since it seems to work fine if I choose other
files, I'll continue on and make the binaries available for now, but wanted to
report the glitch.
Scott
Nv_mkPanelMenu 2 0
Nv_mkPanelMenu 2 1
Nv_mkPanelMenu 2 2
Nv_mkPanelMenu 2 3
Nv_mkPanelMenu 2 4
Error in startup script: integer value too large to represent
while executing
"expr int([lindex $range 1])"
(procedure "mkcutplanePanel" line 55)
invoked from within
"mk$name\Panel $path"
(procedure "Nv_force_panel" line 10)
invoked from within
"Nv_force_panel $i"
(procedure "Nv_mkPanelMenu" line 12)
invoked from within
"Nv_mkPanelMenu $Nv_(AREA).menu.panel"
(procedure "Nv_makeGUI" line 77)
invoked from within
"Nv_makeGUI .top"
(file "/usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script" line 660)
child process exited abnormally
while executing
"exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f /usr/local/grass5/etc/nviz2.2/s
cripts/nviz2.2_script -name NVIZ >&@stdout"
("eval" body line 1)
invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scri
invoked from within
"if {$argv == ""} {
#no arguments
eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scrip
ts/nviz2.2_script -name NVIZ >&@stdo..."
(file "/usr/local/grass5/bin/nviz" line 16)
-------------------------------------------- Managed by Request Tracker
