[GRASS5] Re: [GRASSLIST:2864] Re: GRASS 5.3 Cygwin distribution
Richard Greenwood
rich at greenwoodmap.com
Mon Mar 8 10:09:49 EST 2004
Glynn Clements wrote:
> Richard Greenwood wrote:
>>Regarding "d.mon png" I added gd to 5.0.3 but it still did not work. I
>>also tried it under 5.3 (which supposedly does not require gd) and it
>>did not work there either.
>>Also tried adding fftw as recommended at:
>>http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/grass/documents/release_rules.txt
>>But failed to get it working either.
> Can you provide more details regarding what went wrong?
> I have built both the PNG driver and the programs which require FFTW
> under Cygwin.
I could not find FFTW as part of the Cygwin binary distribution system,
so I downloaded, built and installed FFTW 2.1.5, and enabled FFTW in my
GRASS 5.0.3 configure. The following is the compilation error log. I
assume all these failed due to FFTW problem.
GRASS GIS compilation log
Start of compilation: Sun Mar 7 15:51:03 MST 2004
Errors:
Compilation error in module: src/imagery/i.fft (ignored)
Compilation error in module: src/imagery/i.zc (ignored)
Compilation error in module: src/raster/r.surf.fractal (ignored)
Compilation error in module: src.contrib/CERL/imagery/i.shape (ignored)
End of compilation: Sun Mar 7 16:00:22 MST 2004
DONE generating GRASS GIS binary code
Regarding PNG, I installed the current gd and libgd via the Cygwin setup
program, enabled gd (and png) in my 5.0.3 configure, and received no
errors. However running GRASS:
GRASS:~ > d.mon png
ERROR: no such monitor 'png'
No such monitor as 'png'
Problem selecting png. Will try once more
I recall an earlier email from you in which you said gd was no required
in 5.3, however I get exactly the same error as above in 5.3.
Nviz question: With what versions of GRASS is it appropriate to use and
distribute the Cygwin NVWISH2.2 that you provided?
What would be merits of enabling proj? Although I have it installed
under Cygwin, GRASS configure fails when I try to enable proj.
Regards,
Rich
Richard Greenwood
www.greenwoodmap.com
