[GRASS5] v.in.ogr with spatial
Markus Neteler
neteler at itc.it
Mon Mar 22 10:31:36 EST 2004
Hi Stephan,
the spatial filter in v.in.ogr is fixed in CVS.
Cheers
Markus
On Wed, Mar 17, 2004 at 08:14:38PM +0100, Stephan Holl wrote:
> Dear developers,
> I am trying to import some vector-datasets into GRASS via v.in.ogr. The
> spatial switch does not work as expected, I guess.
> My trys:
> g.region -p
> projection: 99 (Transverse Mercator)
> zone: 0
> datum: potsdam
> ellipsoid: bessel
> north: 5800710
> south: 5788320
> west: 3427050
> east: 3444000
> This is my default region, where the dataset fits inside. I only need
> parts of this shape so I try to import only this giving the 4
> corner-coordinates which include my needed features:
> v.in.ogr -o dsn=PG:dbname=postgis layer=gruen
> spatial=3436830,5794290,3439770,5796780 out=test_spatial
> But after this all featuers including in the dataset were imported.
> Is this the correct usage of the spatial switch ?!
> Thanks for your help
> Stephan Holl
> Stephan Holl
> Check headers for GnuPG Key!
> http://www.gdf-hannover.de
> 20:06:58 up 3:55, 1 user, load average: 0.02, 0.07, 0.16
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
