[GRASS5] color in GRASS
Michael Barton
michael.barton at asu.edu
Tue Mar 23 13:17:09 EST 2004
Somehow this is just not doing the trick--unless my eyes are deceiving
me.
The PNG driver is creating a 44Kb image of the display while xwd is
creating a 1.2 Mb image of the same display. The differences in color
are clearly apparent. As a test, I am just looking at a greyscale
shaded relief map. Will this look paletted as a 24bit PNG? The image
created by xwd does not look paletted and closely matches the display
monitor image.
Michael
On Tuesday, March 23, 2004, at 04:43 AM, Glynn Clements wrote:
> Michael Barton wrote:
>> How difficult is it to at least get 24bit color (or perhaps even get
>> wild with 32bit) to these output routines?
> For 24-bit colour, you need either the recent (GD-less) 5.3 PNG
> driver, or an older PNG driver which was built with GD 2.x. In either
> case, you need to use:
> export GRASS_TRUECOLOR=TRUE
> before starting the PNG driver. You will then get 32-bit PNG files: 8
> bits of each of red, green, blue and alpha. The alpha channel will be
> completely opaque, unless you also use:
> export GRASS_TRANSPARENT=TRUE
> in which case any pixels which aren't drawn will be transparent.
> I'm not sure what you mean by 32-bit colour. The term is sometimes
> used to refer to formats which have an alpha channel, but it can also
> refer to 24-bit data with 8 bits of padding so that pixels are aligned
> to word boundaries (for performance reasons).
> When referring to display depth (e.g. in the Display properties dialog
> on Windows), 32-bit corresponds to the latter, i.e. the extra 8 bits
> are just padding.
> Glynn Clements <glynn.clements at virgin.net>
______________________________
Michael Barton, Professor & Curator
Department of Anthropology
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
