[GRASS5] libgis raster reading
Glynn Clements
glynn.clements at virgin.net
Tue Mar 30 15:17:16 EST 2004
Andrea Antonello wrote:
> I need to understand how GRASS reads and writes the raster data from disk. The
> developer Manual doesn't go much into detail and I'm having big problems to
> get lost inside the code...
No surprise there. I probably understand that code as well as any of
the current developers, and I also get lost inside the code.
FWIW, the relevant files are opencell.c, get_row.c, put_row.c and
closecell.c, all in src/libes/gis.
> Any hint on used algorithms (LZW?)
LZW was used at one point, but isn't supported in 5.x. Integer maps
are stored in big-endian order using a sign bit (*not* twos
complement), with optional run-length compression; floating-point maps
are encoded using XDR and optional zlib (gzip) compression.
The core functions for writing are put_data/put_fp_data. For reading,
there aren't really any core functions; the process seems to be evenly
distributed across most of get_row.c.
> or documentation parts I missed are appreciated.
AFAIK, the only viable source of information on the raster map formats
is the source code.
> PS: is there some project ongoing that aims to rewrite the raster I/O libs in
> any programming language?
I'll probably do it one day, unless someone else gets there first.
Glynn Clements <glynn.clements at virgin.net>
