[GRASS5] Re: grass 5.7 windows?
Radim Blazek
blazek at itc.it
Wed Mar 31 02:19:13 EST 2004
On Tuesday 30 March 2004 18:04, you wrote:
> Hi again,
> I got GRASS 5.7 sort of working under Cygwin
> (see my new install docs at:
> http://grass.itc.it/grass51/binary/mswindows_cygwin/
> -> cygwin_grass.html
> but found a small problem. While d.mon is able to handle
> the XDRIVER.exe file (note the .exe extension under Cygwin),
> the DBMI tools are unable to handle the DBF driver (named dbf.exe
> in $GISBASE/driver/db/dbf.exe ). When I rename the file to
> 'dbf' only it works fine.
> Any ideas what to change to allow for 'dbf.exe' as well?
mon.start is probably using this execl:
#ifdef __W98__
#include <process.h>
#define execl(fullpath,path,name,bg,link,nul) \
do { \
spawnl(_P_DETACH,fullpath,path,name,"-",link,nul); \
return 0; \
} while (0)
#endif /* __W98__ */
-> G_execl() ?
Radim
