[GRASS5] Re: GRASS 5.3 release
Michael Barton
michael.barton at asu.edu
Fri May 7 12:17:34 EDT 2004
I agreed to get the scripts g.parser compliant, but of course will
welcome any help offered. A month back, I went through and updated as
many 5.3 scripts as I could get to work to 5.7 and submitted them to
Markus. This is about 90% of the work needed. They need to be tested by
others too of course, but should work pretty much as is with 5.3.
The biggest change will be in scripts that switched from unnamed
command-line arguments (e.g., script [argument 1$] [argument 2@] ... )
to the 'option=argument' format (e.g., script [option1=value1]
[option2=value2]...). What needs to be done is 1) change the tcltk menu
modules to properly use all new option=value arguments and 2) change
the man pages to also indicate the proper command-line use. This is not
an insignificant number of scripts, but it is not the majority either.
There are also some scripts that don't seem to work in 5.7 and may not
work in 5.3 either. We should probably either fix or deprecate them.
I was going to call the updated version of tcltkgrass 4.1 to indicate
these changes. I doubt if I can get it done by the time you all want to
release 5.3.0, and I DON'T want to hold up this release in any way. Can
I do this to get into a 5.3.x or 5.4 release? How should I number
tcltkgrass? Does it matter?
Michael Barton
______________________________
Michael Barton, Professor & Curator
School of Human Origins, Cultures, & Societies
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
On May 7, 2004, at 2:27 AM, grass5-request at grass.itc.it wrote:
> there are alternatives like r.in.tiff
>> all scripts -> g.parser ?
>> missing man pages (Debian bug #229086, 242436) no
>> Remove any remaining GD,GDBM mentions ?
>> init.sh/set_data race ???? not sure what this was about
>> NVIZ updates done
>> add r.series, r.grow2, d.info **TODO**
>> add r.[in|out].mat, r.univar(2) **TODO**
>> OSX TclTk -> Aqua so close
>> TrueColor for core display modules C done; man pages?
>> shared libs working on all but Cygwin ?
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040507/a70e3656/attachment.bin
