[GRASS5] one fault while running grass57
    Andrea Antonello
    moovida at katamail.com
    Sun May  9 04:41:18 EDT 2004
Hy Zealven,
if you installed proj4 by default,
you should have a /usr/local/lib/libproj.so.0 file.
Does this apply to your case?
If not, where is your proj installation?
Cheers,
Andrea
On Sunday 09 May 2004 08:49, Zealven Xu wrote:
> i need help, while i run grass57, it showed me the following message.
> could any one help me to solve it? actually, i can find the file
> 'libproj.so.0', it means the file libproj.so.0 is existed.
> GRASS 5.7.-cvs:/home/zxu/grass57_exp_2004_05_08 > d.m
> Error in startup script: ps.map: error while loading shared libraries:
> libproj.so.0: cannot open shared object file: No such file or directory
>     while executing
> "exec ps.map -p"
>     (procedure "DmPrint::init" line 14)
>     invoked from within
> "DmPrint::init"
>     (procedure "main" line 30)
>     invoked from within
> "main $argc $argv"
>     (file "/usr/local/grass57/etc/dm/d.m.tcl" line 785)
> _________________________________________________________________
> Help STOP SPAM with the new MSN 8 and get 2 months FREE*
> http://join.msn.com/?page=features/junkmail
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
____________________________________________________________________________
"Let it be as much a great honour to take as to give learning,
if you want to be called wise."
Skuggsja' - The King's mirror - 1240 Reykjavik
University of Trento
Department of Civil and Environmental Engineering
Via Mesiano, 77 - Trento (ITALY)
Andrea Antonello
tel:  +393288497722
fax:  +390461882672
