[GRASS5] [bug #2402] (grass) r.colors - new rules=name option not yet working
Glynn Clements
glynn.clements at virgin.net
Mon May 10 03:08:54 EDT 2004
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2402
> Subject: r.colors - new rules=name option not yet working
> I tried the new rules=[filename] option. It generates ERROR: Unable to
> open rules file [filename].
Where [filename] is what? Does the file actually exist in the
$GISBASE/etc/colors directory?
> Then it stops all processing until a ctrl-C is pressed.
Actually, it pauses for 5 seconds after an error, then exits. Whether
it should pause is debatable.
> I tried a
> simple rules file:
> 1 blue
> 2 green
> end
> (I tried it with and without 'end' and got the same result)
Are you expecting rules= to read a rules file from the current
directory? Because that isn't what the rules= option is meant for. If
you want it to read your own rules file, use color=rules and shell
redirection e.g.:
r.colors mapname color=rules < rulesfile
> Also, it won't even get this far from the autogenerated GUI because it
> conflicts with the type=[option] argument. There needs to be a 'none'
> selection for the type option in the GUI header.
It needs to be a separate menu entry; exactly the same issue also
applies to the rast= option.
Glynn Clements <glynn.clements at virgin.net>
