[GRASS5] [bug #2402] (grass) r.colors - new rules=name option not yet working
Glynn Clements
glynn.clements at virgin.net
Mon May 10 21:13:10 EDT 2004
Markus Neteler wrote:
> > > Also, it won't even get this far from the autogenerated GUI because it
> > > conflicts with the type=[option] argument. There needs to be a 'none'
> > > selection for the type option in the GUI header.
> > It needs to be a separate menu entry; exactly the same issue also
> > applies to the rast= option.
> What about a function which reports the names of the currently
> existing files in $GISBASE/etc/colors/ ? A function which
> returns the file names as comma separated list?
The problem here is that the list could grow rather quickly now that
it can be extended without having to write any code.
Glynn Clements <glynn.clements at virgin.net>
