[GRASS5] v.in.ogr with spatial
Hamish
hamish_nospam at yahoo.com
Wed May 12 22:00:04 EDT 2004
On Mon, 22 Mar 2004 16:31:36 +0100
Markus Neteler <neteler at itc.it> wrote:
> the spatial filter in v.in.ogr is fixed in CVS.
> > Stephan wrote:
> > I am trying to import some vector-datasets into GRASS via v.in.ogr.
> > The spatial switch does not work as expected, I guess.
This still doesn't work for me:
v.in.ogr dsn=. layer=rivers output=rivers \
spatial=1084000,4847000,1224000,5092000
It imports everything.
G5.7> v.info rivers
| Layer: rivers
| Map Scale: 1:1
| Map format: native
| Type of Map: Vector (level: 2)
| Number of points: 0 Number of areas: 0 |
| Number of lines: 749453 Number of islands: 0 |
| Number of boundaries: 0 Number of faces: 0 |
| Number of centroids: 0 Number of kernels: 0 |
| Map is 3D: 0
| Number of dblinks: 1
| Projection: Transverse Mercator (zone 0)
| N: 6221336.075 S: 4748882.679
| E: 2088905.215 W: 1090205.719
| B: 0.000 T: 0.000
Hamish
