[GRASS5] grass + kernel 2.6
Stephan Holl sholl at gmx.net
Mon May 17 12:37:44 EDT 2004
Hello Hamish,
On Mon, 17 May 2004 12:23:37 +1200 Hamish <hamish_nospam at yahoo.com>
wrote:
> > > > did anyone try to compile grass on a system with the 2.6 kernel?
> > > > Any problem?
> > > I compiled 5.3 / 5.7 on new SuSe 9.1 with:
> > > kernelversion 2.6
> > > gcc (GCC) 3.3.3 (SuSE Linux)
> > Did you manage to compile r.terraflow on this system as well?!
> > I did not succeed in compiling r.terraflow with gcc-Version 3.3.3
> > (Debian 20040401).
> > Perhaps anybody knows a workaround.
> FWIW, I'm running Debian/testing with Debian's stock
> kernel-image-2.4.26+ 'gcc (GCC) 3.3.3 (Debian 20040401)'. r.terraflow
> compiles fine in both 5.3 and 5.7.
My kernel is an original kernel from kernel.org and gcc is same as yours
on debian testing.
> What's the error?
OK, thanks for asking.
due the error is a little big, grab it from here:
	http://www.gdf-hannover.de/holl/tmp/error.log.gz
<excerpt>
In function `__tcf_0':
/usr/include/c++/3.3/iostream:77: undefined reference to
`std::ios_base::Init::~Init
[in-charge]()'./IOStream/lib/libiostream.a(ami_stream.o)(.eh_frame+0x11
): In function `ami_single_temp_name(char*,
char*)':/home/steph/cvs/grass53_cvs/src.contrib/DUKE/r.terraflow/IOStre
am/lib/src/ami_stream.cc:63: undefined reference to
`__gxx_personality_v0'./IOStream/lib/libiostream.a(rtimer.o)(.eh_frame+
0x11): In function `rt_sprint_safe(char*,
Rtimer)':/home/steph/cvs/grass53_cvs/src.contrib/DUKE/r.terraflow/IOStr
eam/lib/src/rtimer.cc:52: undefined reference to `__gxx_personality_v0'
collect2: ld returned 1 exit status make: ***
[/home/steph/cvs/grass53_cvs/dist.i686-pc-linux-gnu/etc/bin/cmd/r.terra
flow] Fehler 1
</excerpt>
> The only recent r.terraflow change I'm aware of is 'make' ->
> '$(MAKE)'.
This is not making any problems. see above. btw I did never manage to
make r.terraflow to compile.
Thanks.
	Stephan
Stephan Holl
Check headers for GnuPG Key!
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040517/df5b94c5/attachment.bin
