[GRASS5] grass + kernel 2.6
Stephan Holl sholl at gmx.net
Tue May 18 01:26:22 EDT 2004
Hello Hamish,
> > > > Did you manage to compile r.terraflow on this system as well?!
> > > > I did not succeed in compiling r.terraflow with gcc-Version 3.3.3
> > > > (Debian 20040401).
> > > > Perhaps anybody knows a workaround.
> > > FWIW, I'm running Debian/testing with Debian's stock
> > > kernel-image-2.4.26+ 'gcc (GCC) 3.3.3 (Debian 20040401)'.
> > > r.terraflow compiles fine in both 5.3 and 5.7.
> > My kernel is an original kernel from kernel.org and gcc is same as
> > yours on debian testing.
> 2.6 or 2.4?
it is still 2.4.25 with grsec-patch, but my intention of stepping in this
thread was the gcc-3.3.3 thingy...
> > > What's the error?
> > OK, thanks for asking.
> > due the error is a little big, grab it from here:
> > 	http://www.gdf-hannover.de/holl/tmp/error.log.gz
> cd /home/steph/cvs/grass53_cvs/src.contrib/DUKE/r.terraflow
> ../../../bin.i686-pc-linux-gnu/gmake53
Thats what I exactly did and it results in the error.log.gz-file mentioned
above.
> Maybe you have a missing/corrupt g++ -dev package?
> Is the libstdc++5-dev package installed?
> libc6-dev ?(!)
> fyi, lines 76-78 of /usr/include/c++/3.3/iostream read:
>   // For construction of filebuffers for cout, cin, cerr, clog et. al.
>   static ios_base::Init __ioinit;
> } // namespace std
Usually I have a full build-environment installed, so this should not be the
problem. But I will check this later this day.
THanks for the hints!
Cheers
       Stephan
NEU : GMX Internet.FreeDSL
Ab sofort DSL-Tarif ohne Grundgebühr: http://www.gmx.net/dsl
