[GRASS5] [bug #2415] (grass) GISGEN failure at STEP: src/raster/r.mapcalc3
Request Tracker
grass-bugs at intevation.de
Wed May 19 11:05:49 EDT 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2415
Subject: GISGEN failure at STEP: src/raster/r.mapcalc3
Platform: other
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: 2004_05_15
It's impossible to build new r.mapcalc3 module. This is the error:
gcc -L/grass53_exp_2004_05_15/src/libes/LIB.powerpc-apple-darwin6.8 -prebind -L/usr/X11R6/lib -L/usr/local/grasslib/lib -o /Volumes/APPLI/src/grass53_exp_2004_05_15/dist.powerpc-apple-darwin6.8/etc/bin/cmd/r3.mapcalc OBJ.powerpc-apple-darwin6.8/y.tab.o OBJ.powerpc-apple-darwin6.8/lex.yy.o OBJ.powerpc-apple-darwin6.8/evaluate.o OBJ.powerpc-apple-darwin6.8/expression.o OBJ.powerpc-apple-darwin6.8/function.o OBJ.powerpc-apple-darwin6.8/check.o OBJ.powerpc-apple-darwin6.8/main.o OBJ.powerpc-apple-darwin6.8/xabs.o OBJ.powerpc-apple-darwin6.8/xadd.o OBJ.powerpc-apple-darwin6.8/xand.o OBJ.powerpc-apple-darwin6.8/xatan.o OBJ.powerpc-apple-darwin6.8/xcos.o OBJ.powerpc-apple-darwin6.8/xdiv.o OBJ.powerpc-apple-darwin6.8/xdouble.o OBJ.powerpc-apple-darwin6.8/xeq.o OBJ.powerpc-apple-darwin6.8/xeval.o OBJ.powerpc-apple-darwin6.8/xexp.o OBJ.powerpc-apple-darwin6.8/xfloat.o OBJ.powerpc-apple-darwin6.8/xge.o OBJ.powerpc-apple-darwin6.8/xgraph.o OBJ.powerpc-apple-darwin6.8/xgt.o OBJ.powerpc-a
pple-darwin6.8/xif.o OBJ.powerpc-apple-darwin6.8/xint.o OBJ.powerpc-apple-darwin6.8/xisnull.o OBJ.powerpc-apple-darwin6.8/xle.o OBJ.powerpc-apple-darwin6.8/xlog.o OBJ.powerpc-apple-darwin6.8/xlt.o OBJ.powerpc-apple-darwin6.8/xmax.o OBJ.powerpc-apple-darwin6.8/xmedian.o OBJ.powerpc-apple-darwin6.8/xmin.o OBJ.powerpc-apple-darwin6.8/xmod.o OBJ.powerpc-apple-darwin6.8/xmode.o OBJ.powerpc-apple-darwin6.8/xmul.o OBJ.powerpc-apple-darwin6.8/xne.o OBJ.powerpc-apple-darwin6.8/xneg.o OBJ.powerpc-apple-darwin6.8/xnot.o OBJ.powerpc-apple-darwin6.8/xnull.o OBJ.powerpc-apple-darwin6.8/xor.o OBJ.powerpc-apple-darwin6.8/xpow.o OBJ.powerpc-apple-darwin6.8/xrand.o OBJ.powerpc-apple-darwin6.8/xround.o OBJ.powerpc-apple-darwin6.8/xrowcol.o OBJ.powerpc-apple-darwin6.8/xsin.o OBJ.powerpc-apple-darwin6.8/xsqrt.o OBJ.powerpc-apple-darwin6.8/xsub.o OBJ.powerpc-apple-darwin6.8/xtan.o OBJ.powerpc-apple-darwin6.8/map3.o OBJ.powerpc-apple-darwin6.8/xcoor3.o OBJ.powerpc-apple-darwin6.8/xres3.o -lgis -l
intl -lbtree -lg3d -L/usr/local/grasslib/lib -lreadline -lhistory -lz
ld: warning prebinding disabled because dependent library: /usr/local/grasslib/lib/libintl.1.dylib is not prebound
ld: Undefined symbols:
_G__write_colors
_G_make_rainbow_fp_colors
_G_mark_colors_as_fp
_G_read_colors
_G_define_option
make[1]: *** [/src/grass53_exp_2004_05_15/dist.powerpc-apple-darwin6.8/etc/bin/cmd/r3.mapcalc] Error 1
r.mapcalc3 of this dev version add support for G3d volumes (r3.mapcalc) but it's impossible to build. Old versions are OK
-------------------------------------------- Managed by Request Tracker
