[GRASS5] GRASS 5.7 release
Radim Blazek
blazek at itc.it
Fri May 21 12:02:04 EDT 2004
Sorry, I forgot to commit deleted files, fixed now, update
lib/vector/Vlib or simply delete lib/vector/Vlib/*_shp.c
lib/vector/Vlib/*_post.c
Radim
On Friday 21 May 2004 17:18, Funkmeister wrote:
> Hi Radim, Could this be possibly causing some compile problems. I have
> fresh source and I am getting compile errors in Vlib like:
> close_post.c: In function `V1_close_post':
> close_post.c:51: warning: implicit declaration of function `PQfinish'
> close_post.c:51: error: structure has no member named `post'
> and
> build_shp.c: In function `Vect_build_shp':
> build_shp.c:57: error: structure has no member named `shp'
> build_shp.c:64: error: structure has no member named `shp'
> build_shp.c:65: error: structure has no member named `shp'
> build_shp.c:66: error: structure has no member named `shp'
> build_shp.c:74: warning: implicit declaration of function
> `V1_read_next_line_shp'
> build_shp.c:80: warning: implicit declaration of function
> `Vect_last_line_offset_shp'
> build_shp.c:97: warning: passing arg 1 of `G_malloc' as signed due to
> prototype
> build_shp.c:98: warning: passing arg 1 of `G_malloc' as signed due to
> prototype
> build_shp.c:99: warning: passing arg 1 of `G_malloc' as signed due to
> prototype
> build_shp.c:107: error: structure has no member named `shp'
> build_shp.c:111: warning: passing arg 2 of `G_realloc' as signed due to
> prototype
> build_shp.c:112: warning: passing arg 2 of `G_realloc' as signed due to
> prototype
> build_shp.c:113: warning: passing arg 2 of `G_realloc' as signed due to
> prototype
> build_shp.c:132: warning: passing arg 4 of `Vect_append_point' as
> floating rather than integer due to prototype
> build_shp.c:232: warning: passing arg 4 of `Vect_append_point' as
> It seems to be related to:
> struct Format_info {
> int i;
> #ifdef HAVE_OGR
> struct Format_info_ogr ogr;
> #endif
> which has no members shp or post, etc.
> How do I fix this?
> Thanx
> Craig
> On 21-May-04, at 8:46 AM, Radim Blazek wrote:
> > I have removed Shapefile/PostGIS support from vector library
> > and enabled multi sessions. Please test!
> > I want to release 5.7.0 7.-11. June.
> > Radim
> > grass5 mailing list
> > grass5 at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass5
> grass5 mailing list
