[GRASS5] Re: external proj, gdal, and tcltk
Michael Barton michael.barton at asu.edu
Fri May 21 13:00:43 EDT 2004
Lorenzo Moretti has done this with his binary distribution. The
libraries come as a separate package that you can install if you'd
like. They install in a separate /usr/local/grasslib directory so as
not to overwrite something you already have and the path to this is
dealt with in init.sh and a start up script. It works very well. My
only trouble has been occasional confusion by a program over which
version of what to use when I have multiples.
Michael
______________________________
Michael Barton, Professor & Curator
School of Human Origins, Cultures, & Societies
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
On May 21, 2004, at 9:18 AM, grass5-request at grass.itc.it wrote:
> Maybe just make a PROJ and GDAL binary distribution that have been
> tested with the GRASS binaries, and distribute them all together. Is
> there an easy equivalent to the GRASS 'make bindist' for making PROJ.4
> and GDAL binary packages?
> Paul
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040521/01badd58/attachment.bin
