[GRASS5] [bug #2423] (grass) ps.map raster drawing filesize
Glynn Clements
glynn.clements at virgin.net
Mon May 24 00:04:13 EDT 2004
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2423
> Subject: ps.map raster drawing filesize
> As it is, when ps.map draws a raster map all NULL cells are drawn with
> whatever color they were given with r.colors (usually white). This is
> fine, but results in the same PostScript filesize regardless of the
> number of NULLs in the map.
> I have a 1400x2000 map which is only 3% non-NULL, but the filesize is
> still 20mb; mostly FFFFFF's. Is it at least possible to replace a line
> of all NULLs with a y_position++ type PS command, even if raster data
> must be written in blocks[*]?
It would probably be easier to replace the call to "readhexstring"
with a procedure which decodes e.g. run-length encoded data (and
encode the actual image data accordingly).
Otherwise, you would need a y_position+=dy type command, which means
that you have to figure out what dy should be.
> or shrink the actual PS raster box to
> the outer bounds of the non-NULL data & reposition?
That would be feasible.
> see grass/src/ps.map/ps.map/cmd/rast_plot.c ps_write_mask_row()
Yep. That's the file you need to change ;)
Glynn Clements <glynn.clements at virgin.net>
