[GRASS5] [bug #2424] (grass) creating new location with grass57
Michael Barton michael.barton at asu.edu
Mon May 24 12:47:19 EDT 2004
Are you perhaps trying to do this using a Mac OSX system? This has
happened under OSX for a long time and no one seems to know why. The
tcltk entry screen is supposed to take you to a text screen to create
the new location, but it didn't. The alternative is to start grass in
text mode (>grass57 -text) when you want to make a new location.
However, I just downloaded and installed Lorenzo Moretti's new binaries
from 15 May 2004 and the new location button finally seems to work
properly on my Mac. I will have to try this out more.
Michael Barton
______________________________
Michael Barton, Professor & Curator
School of Human Origins, Cultures, & Societies
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
On May 24, 2004, at 3:01 AM, grass5-request at grass.itc.it wrote:
> From: Request Tracker <grass-bugs at intevation.de>
> Date: May 24, 2004 1:55:34 AM MST
> To: grass5 at grass.itc.it
> Cc: Subject: [GRASS5] [bug #2424] (grass) creating new location with
> grass57
> Reply-To: Request Tracker <grass-bugs at intevation.de>
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2424
> when creating a new location with grass 5.7 (i installed precompiled
> binaries
> 10.5.04) no location is created. the following is displayd in the
> command
> window when button 'create location from epsg' :
> g.proj: relocation error:
> /usr/local/grass57-10_05_2004/lib/libgrass_gproj.so:
> undefined symbol: OSRMorphFromESRI
> when i select button 'create new location' i get the following:
> GRASS 5.7.-cvs:~/diss/grassdata > Error in startup script: ERROR:
> LOCATION_NAME not set
>     while executing
> "exec ps.map -p"
>     (procedure "DmPrint::init" line 14)
>     invoked from within
> "DmPrint::init"
>     (procedure "main" line 30)
>     invoked from within
> "main $argc $argv"
>     (file "/usr/local/grass57-10_05_2004/etc/dm/d.m.tcl" line 786)
> after this message i have to repair my .grass57-file.
> thanks, sabine
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040524/8b9c596f/attachment.bin
