[GRASS5] [bug #2426] (grass) v.to.db - adding unit 'square meter'
Radim Blazek
blazek at itc.it
Tue May 25 07:41:33 EDT 2004
On Tuesday 25 May 2004 12:47, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2426
> Subject: v.to.db - adding unit 'square meter'
> Platform: GNU/Linux/i386
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> GRASS Version: GRASS 5.7 CVS (20040525)
> Dear Developers,
> I would like to see a 'square meter' unit integrated in the v.to.db
> module. Currently supported volumes are acres and hectares.
> units mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)
> And I would need to do something like:
> v.to.db map=map option=area units=sqm col1=area
miles, feets, meters and kilometers are square for option=area.
Did you get wrong results?
Radim
