[GRASS5] [bug #2432] (grass) Error after entering location and mapset and database
Glynn Clements glynn.clements at virgin.net
Thu May 27 04:46:21 EDT 2004
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2432
> Subject: Error after entering  location and mapset and database
> 1.I downloaded the sample data file spearfish_grass53data.tar.gz in /usr/grass5
> 2.I extract it to /usr/grassdata
> Then  I start  grass5
>  and enter the entries as :
> LOCATION:   spearfish_____             (enter list for a list of locations)
> MAPSET:     user1_________             (or mapsets within a location)
> DATABASE:   /usr/grassdata____________________________________
> I get this thing :
> Sorry, no access to <<user1>>.
You can only select a mapset which you own (in the sense of Unix file
ownership).
>             SO What to do now.
Either enter a different mapset (if you enter a non-existent mapset,
it will be created), or change the ownership of the user1
subdirectory.
Glynn Clements <glynn.clements at virgin.net>
