[GRASS5] [bug #2442] (grass) v.random gives error
Request Tracker grass-bugs at intevation.de
Sun May 30 11:00:03 EDT 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2442
Subject: v.random gives error
Platform: other
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 5.7_040526
Tried using v.random module, using name random and value 10
terminal gave :
GRASS 5.7.-cvs > invalid command name "default=rand()"
bad window path name ".pw.f0.frame.optwin.fra.frame.val3.chk"
error log gave
can't read "optval(3)": no such element in array
    while executing
"if { $optval($i) == 1 } {
                append cmd " -$optname($i)"
    (procedure "mkcmd" line 33)
    invoked from within
"mkcmd "
    invoked from within
".run invoke"
    ("uplevel" body line 1)
    invoked from within
"uplevel #0 [list $w invoke]"
    (procedure "tk::ButtonUp" line 22)
    invoked from within
"tk::ButtonUp .run"
    (command bound to event)
-------------------------------------------- Managed by Request Tracker
