[GRASS5] Porting list
Huidae Cho
grass4u at gmail.com
Mon Nov 1 12:58:48 EST 2004
I'm attaching a list, so could anyone update this? BTW, it would be
great if things like this can be done in GRASS Wiki. No one uses it?
Thanks,
Huidae Cho
On Mon, 1 Nov 2004 14:46:09 +0100, Markus Neteler <neteler at itc.it> wrote:
> On Mon, Nov 01, 2004 at 01:31:47AM -0600, Huidae Cho wrote:
> > Hi list,
> > Is there any module list that should not be ported to 5.7 from 5.3?
> Yes,
> http://grass.itc.it/grass57/index.html#docs
> -> GRASS 5.7 vector modules upgrade status
> -> http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass51/doc/vector/v.modules.html
> > Currently, I can find many modules are missing in 5.7.
> Please post a list of module not appearing in above list.
> Up to now we only transferred modules of interest to 5.7.
> Your list might be helpful to identify further modules needed.
> Cheers
> Markus
5.3 modules not found in 5.7
d.3d
may be obsolete?
d.area
merged to d.vect: HTMLMAP driver doesn't work with new d.vect
d.colormode
d.db
d.display
deprecated?
d.extend
d.fix.ortho
d.icons
d.label
d.labels
d.menu
d.pan
d.points
d.rast.pg
d.site.labels
d.site.pg
d.sites
d.vect type=points?
d.sites.qual
d.vect.area
merged to d.vect
d.vect.labels
merged to d.vect
d.vect.line
merged to d.vect
d.vect.pg
merged to d.vect
d.what.db
d.what.r.pg
d.what.s.pg
d.what.sites
d.what.v.pg
merged to d.vect
db.createdb
implemented?
db.databases
implemented? db.tables?
db.dropdb
implemented? db.droptable?
g.column.pg
g.help
g.manual
g.pnmcomp
g.select.pg
implemented?
g.stats.pg
implemented?
g.table.pg
implemented?
i.colors
i.composite
i.in.erdas
i.out.erdas
i.quantize
i.rvi.prediction
i.shape
i.tape.mss
i.tape.mss.h
i.tape.other
i.tape.spot
i.tape.tm
i.tape.tm.fast
i.texture
m.datum.shift
m.dem.examine
m.dem.extract
m.dmaUSGSread
m.dted.examine
m.dted.extract
m.examine.tape
m.flip
m.futil
m.gc2ll
m.in.e00
E00 should be added to OGR library
m.in.stf1.tape
m.ipf
m.kappa
m.ll2gc
m.ll2u
m.lulc.USGS
m.lulc.read
m.proj2
m.qcalc
m.region.ll
m.rot90
m.sdts.read
m.strip99s
m.svfit
m.tiger.region
m.u2ll
p.chart
p.colors
p.icons
p.labels
p.map
not used in 5.0
p.map.new
p.ppm
p.select
p.vrml
pg.in.dbf
ps.icon
ps.select
r.binfer
r.colors.paint
r.flowmd
this is old, use r.flow
r.grow2
r.hydro.CASC2D
r.in.doq
r.in.dted
r.in.elas
r.in.ll
r.in.miads
r.in.pbm
r.in.pgm
r.in.gdal
r.in.ppm
r.in.shape
r.in.sunrast
r.in.tang
r.in.tiff
r.in.gdal
r.in.utm
r.infer
r.line
r.linear.regression
r.mask
r.mask.points
r.out.elas
r.out.rlc
r.out.tga
r.out.xyz
r.poly
r.rational.regression
r.reclass.scs
r.rvi.prediction
r.support
r.surf.idw2
r.to.sites
r.volume
r.water.fea
r.weight
r.weight2
r3.to.sites
s.cellstats
s.delaunay
s.hull
s.in.ascii
temporary for debugging
s.in.dbf
replaced by v.in.db
s.in.shape
Shapefile supported by v.in.ogr
s.info
v.info
s.kernel
s.mask
s.medp
the old version (GRASS 5.3) is buggy and cannot be simply updated, more work needed.
s.normal
s.out.ascii
s.out.e00
sites not used in 5.1/7
s.perturb
s.probplt
requires gnuplot
s.proj
sites not used in 5.1/7, v.proj
s.qcount
s.random
v.random
s.sample
s.surf.idw
v.surf.idw
s.surf.rst
merged to v.surf.rst
s.sv
s.territory
s.to.rast
v.to.rast
s.to.rast3
s.to.vect
s.univar
s.vol.idw
s.vol.rst
s.voronoi
s.what
sites not used in 5.1/7, v.distance
s.windavg
v.alabel
will be merged by v.category
v.apply.census
v.area
the same functionality in d.what.vect
v.autocorr
v.bubble
replaced by v.buffer
v.cadlabel
can be done by v.distance
v.circle
v.cutter
replaced by v.overlay
v.db.reclass
move to v.reclass
v.dump
the same functionality in v.to.db
v.export
v.import
v.in.arc
v.in.atlas
atl2dig2.c is not used
v.in.dlg
v.in.dlg.scs
not used in 5.0
v.in.dlg2
not used in 5.0
v.in.dxf
replaced by v.in.dwg
v.in.dxf3d
replaced by v.in.dwg?
v.in.gshhs
v.in.poly
v.in.sdts
SDTS supported by v.in.ogr
v.in.shape
v.in.tig.basic
TIGER supported by v.in.ogr?
v.in.tig.lndmk
v.in.transects
v.llabel
replaced by v.category
v.mkquads
not used in 5.0?
v.mkstats
v.out.arc
v.out.atlas
v.out.dlg
v.out.dxf
v.out.e00
v.out.idrisi
v.out.mapinfo
Mapinfo is supported by v.out.ogr
v.out.moss
v.out.sdts
SDTS is NOT supported by v.out.ogr
v.out.shape
Shapefile is supported by v.out.ogr
v.patch.scs
v.prune
this functionality should go to v.clean
v.reclass.pg
moved to v.reclass?
v.report
replaced by v.to.db
v.rm.dangles
merged to v.clean
v.rmdup
merged to v.clean
v.rmedge
v.scale.random
v.sdts.dq.cp
v.sdts.meta
v.sdts.meta.cp
v.spag
merged to v.clean
v.split
v.stats
the same functionality in v.info
v.support
v.timestamp
move to v.info?
v.to.pg
v.to.sites
Sites replaced by vector points
v.what
this functionality is available in v.distance
