[GRASS5] Without FreeType
Glynn Clements
glynn at gclements.plus.com
Fri Nov 5 04:53:00 EST 2004
Radim Blazek wrote:
> I have 5.7 configured without FreeType and compilation fails in
> grass51/display/drivers/lib:
> Text3.c:14:22: ft2build.h: No such file or directory
> Text3.c:15:10: #include expects "FILENAME" or <FILENAME>
> Text3.c:25: parse error before '*' token
One consequence of the recent updates to the display drivers is that
FreeType is no longer an optional dependency. If you don't have it,
you can't build the display drivers.
The --with[out]-freetype option only affects d.text.freetype.
