[GRASS5] Re: 5.7: man pages generated now
Fri Nov 5 05:04:14 EST 2004
Glynn Clements wrote:
> > two problems are remaining for the MAN page creation in 5.7:
> > 1) this error:
> > cd man
> > make
> > Converting: xganim.html to /home/neteler/soft/57grass_cvsexp/dist.i686-pc-linux-gnu/man/man1/xganim.1
> > /bin/sh: line 1: [: too many arguments
> > make[1]: Leaving directory `/home/neteler/soft/57grass_cvsexp/man'
> > I don't know why and where it appears in the Makefile.
> Please start from mk/Makefile.docs in 5.3, not html/Gmakefile.
> If you want to generate a file only if it doesn't exist or if it is
> older than its source file, use "make" (as opposed to writing a
> mini-make using /bin/sh and getModTime).
I've changed man/Makefile accordingly; it seems to work OK.
