[GRASS5] CVS downtime for file copy
Bernhard Reiter
bernhard at intevation.de
Fri Nov 5 10:14:33 EST 2004
On Fri, Nov 05, 2004 at 02:45:57PM +0100, Radim Blazek wrote:
> Radim Blazek wrote:
> >Bernhard Reiter wrote:
> >>Afterwards the list of files can be used to use cvs admin command
> >>to set a state or so, if you want to mark it.
> >It would be good to add a new log message for each file telling where it
> >comes from. I don't see however any cvs command which can add a log
> >message without changes in code. cvs admin can only change existing
> >message.
> cvs commit -f -m
I do not have much experience with that command.
What do you think about boosting the revision to 2.0?
Like with cvs commit -r2.0
That would also be an additional clear sign.
> should do that. Bernhard, could you add these messages immediately
> after you copy the files. Something like
> -m "copy from grass/xxx/yyy/zzz.c"
I will have to try, because the copying is in the repository
while the cvs command has to work on a working copy.
Right after copying I do not have a working copy.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20041105/34104a21/attachment.bin
