[GRASS5] nviz segfault with grass5.7.0
Soeren Gebbert
soeren at pool.math.TU-Berlin.DE
Fri Nov 5 21:34:07 EST 2004
On Sat, 6 Nov 2004, Hamish wrote:
> > i have a problem with nviz, if i try to visualize a rasterfile i get a
> > segmentationfault:
> > Loading Data
> > child killed: segmentation violation
> [rest is Tcl cruft]
> > while executing
> > "exec /usr/local/grass-5.7.0/etc/nviz2.2/NVWISH2.2 -f
> > /nviz2.2/scripts/nviz2.2_script -q -name NVIZ >&@stdout"
> > ("eval" body line 1)
> > invoked from within
> > "eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
> > $env(GISBASE)/etc/nviz2.2/scri
> > pts/nviz2.2_script $argv -name NVIZ >&@stdout"
> > invoked from within
> > "if {$argv == ""} {
> > #no arguments
> > $env(GISBASE)/etc/nviz2.2/scrip
> > ts/nviz2.2_script -name NVIZ >&@stdo..."
> > (file "/usr/local/grass-5.7.0/bin/nviz" line 16)
> > The problem shows up only with rasterfiles.
> > I think the reason is, that i running a 64Bit
> > Linux on AMD 3000+ 64Bit. Do you have any hints to solve the problem?
> some things to try first:
> Set the region to include data?
> g.region rast=rastermap
yes, i tried differend regions.
> Is the map's range != 0?
> r.info -r rastermap
I have no "working" rastermap (and i have a lot), even the maps from 32Bit
systems are not working. But if i declare a constant in nviz (as map AND color), then it
works.
> > I'm a skilled C-programmer, maybe i can help you?
> Debugging NVIZ hints from Glynn
> http://article.gmane.org/gmane.comp.gis.grass.devel/2010
> > > AFAICT from the error message, it's the core NVIZ process which
> > > crashed; i.e. not the "nviz" script, but the NVWISH2.2 binary
> > > interpreting nviz2.2_script. To debug that, you would need to emulate
> > > the "nviz" script by setting up the various environment variables,
> > > then running NVWISH2.2 under gdb, e.g.:
> > > export GISDBASE=`g.gisenv get=GISDBASE`
> > > export LOCATION_NAME=`g.gisenv get=LOCATION_NAME`
> > > export MAPSET=`g.gisenv get=MAPSET`
> > > gdb /usr/local/grass5/etc/nviz2.2/NVWISH2.2
> > > > run -f /usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script
> > > > -name NVIZ
> good luck,
> Hamish
thanks
Best regards
Sören
