[GRASS5] v.in.dwg, Cannot open database
Kirk R. Wythers
kwythers at UMN.EDU
Mon Nov 8 10:00:40 EST 2004
On Nov 5, 2004, at 6:36 PM, Hamish wrote:
>>>> Anyone recognize this one? I'm using the older OpenDWG Toolkit
>>>> (haven't figured out the newer DWGDirect file structure yet).
>>>> GRASS 5.7.cvs:~ > v.in.dwg input=/Volumes/disk2/data2/ccgis/cc1.dxf
>>>> output=Boundary layers=Boundary
>>>> WARNING: The vector 'Boundary' already exists and will be
>>>> overwritten.
>>>> dbmi: db_open_database() not implemented
>>>> WARNING: Cannot open database
>>>> '/usr/local/share/grassdata/cecr_utm/ccgis/dbf/'
>>>> ERROR: Cannot open database
>>>> by driver dbf
>>>> GRASS 5.7.cvs:~ >
>>> Does 'db.connect -p' work?
>> Gives:
>> GRASS 5.7.cvs:~ > db.connect -p
>> driver:(null)
>> database:(null)
> Ok, you need to tell it what kind of database you want the attribute
> data to be stored in, e.g.:
> db.connect driver=dbf database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/'
If I issue the db.connect command to the location and mapset that I'm
trying to read the dxf file into, it correctly shows that there is
nothing as of yet in the directory dbf:
GRASS 5.7.cvs:~ > db.connect driver=dbf
database=~/grassdata/cecr_utm/ccgis/dbf/
driver:dbf
database:/Users/kirkw/grassdata/cecr_utm/ccgis/dbf/
However, double checking with the spearfish dataset, it correctly
shows the soils database.
database=~/grassdata/spearfish57/PERMANENT/dbf/soils.dbf
driver:dbf
So it looks like db.connect works
Kirk R. Wythers
Dept. of Forest Resources
University of Minnesota
email: kwythers at umn.edu
tel: 612.625.2261
fax: 612.625.5212
