[GRASS5] Messages and GUI
Michael Barton
michael.barton at asu.edu
Mon Nov 15 09:07:48 EST 2004
On 11/14/04 9:37 PM, "Hamish" <hamish_nospam at yahoo.com> wrote:
>>>>>> I have added G_messages and modified a bit G_percent, G_warning
>>>>>> and G_fatal_error. If GRASS_MESSAGE_FORMAT enviroment (not GRASS)
>>> variable>>>is set to 'gui', those functions print messages in format
>>>>>> suitable for parsing by GUI. gui.tcl was also modified and
>>>>>> displays progress bar if G_percent is used and adds icons to
>>> output box.>>>http://mpa.itc.it/radim/g51/messages1.png
> Should d.m set GRASS_MESSAGE_FORMAT=gui? and if so, should it pop up a
> window or draw on the main screen?
I would vote for setting GRASS_MESSAGE_FORMAT=gui. If someone is using d.m,
they want a GUI and graphic display or at least don't mind it enough to turn
it off.
For where it shows up, I'd vote for in the message window of the module that
is running (I realize that was not one of the choices, but is the most
logical). 2nd choice would be in a popup. The main GRASS term is overly busy
as it is.
Michael
> right now it dumps to the term that started d.m:
> GRASS_INFO_PERCENT: 78
> GRASS_INFO_PERCENT: 81
> GRASS_INFO_PERCENT: 84
> GRASS_INFO_PERCENT: 87
> GRASS_INFO_PERCENT: 90
> GRASS_INFO_PERCENT: 93
> GRASS_INFO_PERCENT: 96
> GRASS_INFO_PERCENT: 99
> GRASS_INFO_PERCENT: 100
> Hamish
____________________
C. Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
