[GRASS5] [bug #2693] (grass) problem importing tif files
Markus Neteler
neteler at itc.it
Tue Nov 16 11:31:34 EST 2004
On Tue, Nov 16, 2004 at 10:30:34AM +0100, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2693
> Subject: problem importing tif files
> I have a problem when I import a tif file with r.in.gdal command, it takes an
> error:
> r.in.gdal: error while loading shares libraries: libodbc.so.1 cannot open
> share d object file: no such file or directory
You will have do install the ODBC libraries as the GDAL libraries
on your system obviously depend on that.
> With r.in.tiff I cannot import the file too, the program doesn't find the file!
Please post the command line or parameters.
Markus
