[GRASS5] Re: vector point dataset
Radim Blazek
blazek at itc.it
Wed Nov 17 08:15:34 EST 2004
You can delete old sidx files manualy or you can run v.build.all.
Radim
Radim Blazek wrote:
> I have submitted the changes: spatial index is not saved to
> file, it is built only if necessary. It is built automaticaly
> if Vect_select_* is called, but it is probably better
> to call Vect_build_spatial_index from module (like in d.what.vect).
> Another change: it took lang time to free memory occupied by support
> structures and usually it is not necessary. So now, by default
> support structures are not released when vector is closed.
> This reduced time for v.build from previous example from 54
> to 39s.
> It is possible to use Vect_set_release_support if necessary
> (for example v.clean). Let me know about other cases where
> Vect_set_release_support should be added.
> Radim
> Brent Wood wrote:
>> On Tue, 16 Nov 2004, Radim Blazek wrote:
>>> I tried to change the library so that spatial index is not
>>> stored to file and it is built only if needed.
>>> Test on vector : 149971 boundaries, 99972 areas, 99972 centroids
>>> module | Old version | New version |
>>> v.build | 55s | 54s |
>>> v.distance (from 1 point ) | 6s | 29s |
>>> v.distance (from 100 points) | 3m50s | 4m30s |
>>> It means, that if a module needs spatial index, it takes
>>> 5 times more time to get it ready then before, but the difference
>>> is less important in real applications, because usually it is
>>> not used just once.
>>> There are circa 10 modules from 60 which needs spatial index.
>>> We can have either faster 10 modules or we can spare the space occupied
>>> by spatial index file.
>>> What is your opinion?
>> Thank you for following this up, 'tis appreciated.
>> Hmm.... I'm not using GRASS much, mostly GMT/QGIS/PostGIS, but I want to
>> do more with GRASS. I appreciate your comment on the value of indices for
>> points. I guess with modern hard drives the space is not a huge issue,
>> and
>> the time taken to import the file & create the index is only a once off,
>> whereas queries are likely to be ongoing.
>> A typical use for me, would be taking 120,000,000 point elevations and
>> building a DEM. I have mainly used GMT for this, so hope to simply import
>> the GMT netCDF grids (so far unsuccesfully), but I was also interested in
>> building the model with GRASS, as it supposedly has some excellent tools
>> for this. I've tried a few times, but so far I have been unable to get a
>> DEM built by GRASS.
>> GMT takes about 3 hrs on a fast PC. The same box with GRASS has been
>> running for 15hrs with no result. I do need to look into this more, & it
>> is not directly in answer to your question, but is background to what I'm
>> trying to achieve with GRASS.
>> As long as GRASS was doing what it should, & the index files are useful I
>> have no problem with them being built.
>> Something I'm not aware of is the approach used by GRASS57 for accessing
>> data from a PostGIS table. If the points were stored in PostGIS and
>> accessed by GRASS, I presume GRASS would not build an index. I have not
>> yet tried to build a DEM using GRASS to work with points in PostGIS.
>> Thanks,
>> Brent
>>> Radim
>>> Radim Blazek wrote:
>>>> It is normal.
>>>> Spatial index is important also for points, I think. Otherwise
>>>> v.distance for example
>>>> must always go through all points. Say that you have another vector
>>>> with
>>>> 4,000,000
>>>> and you want to find the nearst in the first one. Withou spatial
>>>> index it
>>>> must do 4,000,000 x 4,000,000 checks.
>>>> Spatial index is stored as tree of boxes, 6x8 bytes each, so 430 M is
>>>> possible.
>>>> Any advice appreciated....
>>>> Brent Wood wrote:
>>>>> I have a vector point dataset (ascii XYZ, the basis of a DEM).
>>>>> I'm importing into GRASS5.7 with
>>>>> cat <file> | v.in.ascii -Z output=nzxyz xcol=1 ycol=2 zcol=2 catcol=0
>>>>> There are about 4,000,000 XYZ points.
>>>>> The vector coor file is 150Mb. GRASS is now building the topology &
>>>>> index.
>>>>> The topo file is almost 200Mb and the sidx is at 430Mb and growing.
>>>>> Is this normal? It seems very excessive for a point dataset. A spatial
>>>>> index & topology make more sense for line/polygon data, with over
>>>>> 4x the
>>>>> actual data volume to store this extra info doesn't look right
>>>>> somehow...
>>>>> The system is a SuSE Linux 9.1 23 bit OS on A64 3500 with 1Gb memory.
>>>>> Swapped out 1.4Gb & still using 800Mb main memory.
>>>>> Brent Wood
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
