[GRASS5] [bug #2714] (grass) mention v.llabel on v.to.rast
Request Tracker grass-bugs at intevation.de
Tue Nov 23 18:46:35 EST 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2714
Paul> I think v.llabel is the simple way to do this
Sure wish it was mentioned on v.to.rast.
There is should mention more alternatives than just:
"An empty raster map layer will also be created if the vector map
layer has not been assigned category/attribute labels (e.g., through
use of the v.digit program)"
Also on v.llabel,
   A dig_plus file must be created for each imported vector map before it
   can be used in v.digit.
It should mention how to do this.
Also v.llabel mentions v.alabel but not visa versa.
--- Headers Follow ---
>From jidanni at jidanni.org  Wed Nov 24 00:46:35 2004
Return-Path: <jidanni at jidanni.org>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
	by lists.intevation.de (Postfix) with ESMTP id 6B85A102BEC
	for <grass-bugs at lists.intevation.de>; Wed, 24 Nov 2004 00:46:35 +0100 (CET)
Received: from localhost (localhost [127.0.0.1])
	by mail.intevation.de (Postfix) with ESMTP id 3ECD636DE4
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
	by mail.intevation.de (Postfix) with ESMTP id A95E336CD8
	for <grass-bugs at intevation.de>; Wed, 24 Nov 2004 00:46:34 +0100 (CET)
Received: from tc218-187-75-172.2-3.dynamic.apol.com.tw ([218.187.75.172]:35864 helo=jidanni1)
	by frodo.hserus.net with esmtpsa
	(Cipher TLSv1:RC4-SHA:128) (Exim 4.43 #0)
	id 1CWkMh-0005FW-1a by authid <jidanni> with plain; Wed, 24 Nov 2004 05:16:31 +0530
To: grass-bugs at intevation.de
Cc: Paul Kelly <paul-grass at stjohnspoint.co.uk>
Subject: mention v.llabel on v.to.rast
References: <53E31E00-3C29-11D9-BE24-0003937C0D96 at unbc.ca>
	<871xel19s5.fsf at jidanni.org>
	<Pine.LNX.4.60.0411231207210.21957 at agrippa.ukshells.co.uk>
Date: Wed, 24 Nov 2004 04:46:12 +0800
Message-ID: <874qjgs38r.fsf_-_ at jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.5 tagged_above=-999.0 required=3.0 tests=BAYES_00,
	DATE_IN_PAST_03_06
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
