[GRASS5] no links to GRASS 5.4 binaries
Paul Kelly paul-grass at stjohnspoint.co.uk
Thu Nov 25 06:27:44 EST 2004
On Thu, 25 Nov 2004, Florian Goessmann wrote:
>> Is there any volunteer to compile 5.4 binaries (Linux etc)?
> i have compiled 5.4 with this configure output:
> GRASS is now configured for i686-pc-linux-gnu
>  Build Mechanism:           gmake
You should use --enable-gmake=no or --disable-gmake (this is the default)
to get shared libraries. This is important if you are making a binary
package available for download as it will be much smaller.
Paul
