[GRASS5] no links to GRASS 5.4 binaries
Markus Neteler
neteler at itc.it
Thu Nov 25 10:09:13 EST 2004
On Thu, Nov 25, 2004 at 03:49:54PM +0100, Florian Goessmann wrote:
> i have re-compiled it with all your suggested changes. configure now
> looks like this:
> GRASS is now configured for i686-pc-linux-gnu
> Build Mechanism: Alternate
> Source directory: /home/florian/Documents/SRCes/grass-5.4.0
> Build directory:
> /home/florian/Documents/SRCes/grass-5.4.0/build
> Installation directory: /usr/local/grass54
> C compiler: gcc -g -O3
> C++ compiler: c++ -g -O2
> FORTRAN compiler: g77
> NVIZ: yes
> X11 support: yes
> JPEG support: yes
> TIFF support: yes
> PNG support: yes
> Tcl/Tk support: yes
> PostgreSQL support: yes
> OpenGL(R) support: yes
> SGI IRIS GL support: no
> ODBC support: yes
> FFTW support: yes
> BLAS support: no
> LAPACK support: no
> Motif support: yes
> FreeType support: yes
> GLw support: yes
> NLS support: no
> Readline support: yes
> C++ support: yes
> External PROJ.4 support: yes
> GDAL/OGR support: yes
> you can download it here:
> http://www.geographen.org/files/grass5.4.0_i686-pc-linux-gnu.tar.gz
> in that archive you find the binary archive and the installer script.
Great - nearly realtime.
I have downloaded the package but found it rather large as
it was compiled with -g (debugging) and without -s (stripping).
To be discussed: Should this package come with debugging symbols?
Otherwise
CFLAGS="-O3" LDFLAGS="-s" ./configure ...
will help to make it smaller.
Markus
