[GRASS5] no links to GRASS 5.4 binaries
Fri Nov 26 05:31:47 EST 2004
Florian Goessmann wrote:
> >> when i switch postgreSQL og i get this:
> >> Compilation error in module: src.contrib/GMSL/NVIZ2.2
> >> without readine support i get an error on my system:
> >> Compilation error in module: src/raster/r.mapcalc3
> > You need to run "make clean" (or maybe "make distclean") before
> > re-running configure with different options.
> i did that.
So what are the actual error messages you get when you build with
those options disabled?
