[GRASS5] Debian-Package-Build
Stephan Holl sholl at gmx.net
Fri Nov 26 07:37:11 EST 2004
Dear developers,
[CC: pkg-grass-general]
I try to build a GRASS57-debian package, but found some problems:
* grass57-init-script (/usr/bin/grass57) points to the wrong
direction, still to /where/grasssrc/are/debian/tmp/usr/grass-5.7.cvs
instead to /usr/grass-5.7.cvs/
* modules g.list, g.copy, g.remove, g.rename are missing. When
compiling"normally" everything is built and copied to dist.[Arch]/bin
folder.
thanks for your help.
Cheers
	Stephan
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.enam
