[GRASS5] 5.7: new 'fakestart' concept with demolocation
Glynn Clements
glynn at gclements.plus.com
Fri Nov 26 17:03:05 EST 2004
Markus Neteler wrote:
> upon an idea of Radim I have added a small (68k) demolocation
> into the 5.7 source code directory.
> The 'fakestart' session is now using this demolocation to
> generate the HTML documentation (MAN docs derived from that).
AFAICT, this won't work if the user building GRASS doesn't own the
source tree, due to G__mapset_permissions().
