[GRASS5] Re: [GRASSLIST:4976] Re: Info about 5.4cvs and nviz on 5.7cvs
Bernhard Reiter bernhard at intevation.de
Sat Nov 27 13:35:25 EST 2004
On Fri, Nov 26, 2004 at 03:26:22PM +0100, Markus Neteler wrote:
> On Thu, Nov 25, 2004 at 09:19:51AM +0000, Paul Kelly wrote:
> > On Wed, 24 Nov 2004, Lorenzo Moretti wrote:
> > >After Grass 5.4.0 release I have download the new cvs version
> > >(grass53src_cvs_snapshot_exp_2004_11_20.tar.gz) but I have seen that this
> > >version is like old 5.3 with static libraries for OS X not like 5.4.0 with
> > >shared libs.
> > Yes some of the changes on the 5.4 branch could/should be backported into
> > the CVS HEAD. But there is not much point in using the CVS HEAD as new
> > development has now been moved to 5.7.
> better to disable the CVS snapshot cronjobs for pre-5.7 code?
Why? If there is a 5.4.x CVS with bug fixes (like there should be)
then snapshots would make sense.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20041127/4bbc1065/attachment.bin
