[GRASS5] [bug #2731] (grass) F77, REQUIREMENTS.html
Sun Nov 28 00:18:33 EST 2004
Request Tracker wrote:
> In configure.in: AC_CHECK_PROGS(F77, g77 f77)
> In grass57_exp_2004_11_27/REQUIREMENTS.html F77 is not mentioned.
It doesn't appear to be used in 5.7. In 5.3, it's only used for
modules which aren't built by default:
	src/sites/cdhc
	src.contrib/CERL/SGI/ISM/grid
	src.contrib/CERL/misc/m.eigensystem
	src.garden/answers/src.answers
	src.garden/grass.hdf
	src.garden/grass.rim
In 5.7, lib/cdhc contains four Fortran files, but they aren't actually
used.
The configure check should probably be removed.
