[GRASS5] v.out.ascii: Segmentation fault
Jachym Cepicky
jachym.cepicky at centrum.cz
Mon Nov 29 07:07:40 EST 2004
On Thu, Nov 25, 2004 at 02:01:21PM +0100, Markus Neteler wrote:
> > ./configure --with-cxx --with-postgres-includes=/usr/include/postgresql/ --with-gdal=/usr/local/bin/gdal-config --with-proj --with-motif --with-glw --with-nls --with-freetype --with-freetype-includes=/usr/include/freetype2 --with-tcltk-includes=/usr/include/tcl8.4/
> SO: did configure report to have found Motif and glw and GL etc?
checking whether to use Motif... yes
checking for location of Motif includes...
checking for Xm/Xm.h... yes
checking for location of Motif library...
checking for XmStringCreate in -lXm... yes
checking whether to use GLw... yes
checking for location of GLw includes...
checking for GL/GLwMDrawA.h... yes
checking for location of GLw library...
checking for GLwCreateMDrawingArea in -lGLw... no
checking for GLwCreateM1DrawingArea in -lGLw... yes
Source directory: /usr/src/grass/grass51
Build directory: /usr/src/grass/grass51
Installation directory: /usr/local/grass-5.7.cvs
Startup script in directory: ${exec_prefix}/bin
C compiler: gcc -g -O2
C++ compiler: c++ -g -O2
FORTRAN compiler: g77
Building shared libraries: yes
NVIZ: yes
X11 support: yes
JPEG support: yes
TIFF support: yes
PNG support: yes
Tcl/Tk support: yes
PostgreSQL support: yes
MySQL support: no
OpenGL(R) support: yes
ODBC support: yes
FFTW support: yes
BLAS support: no
LAPACK support: no
Motif support: yes
FreeType support: yes
GLw support: yes
NLS support: yes
Readline support: no
C++ support: yes
openDWG support: no
GDAL support: yes
OGR support: no
I would say, they are there.
> What happens if you run
> cd grass57src
> cd lib/vector/Vlib/
> make clean
> make
> (I only want to know the last (g)cc line where the library is generated.
There they are:
gcc -I/usr/src/grass/grass51/include -I/usr/src/grass/grass51/dist.i686-pc-linux-gnu/include -g -O2 -Wall -Wconversion -Wno-implicit-int -fPIC -DPACKAGE=\""grasslibs"\" -DPACKAGE=\""grasslibs"\" -DPACKAGE=\""grasslibs"\" -I/usr/src/grass/grass51/include -I/usr/src/grass/grass51/dist.i686-pc-linux-gnu/include \
-o OBJ.i686-pc-linux-gnu/tin.o -c tin.c
-o OBJ.i686-pc-linux-gnu/type.o -c type.c
-o OBJ.i686-pc-linux-gnu/window.o -c window.c
-o OBJ.i686-pc-linux-gnu/write.o -c write.c
write.c:43: warning: initialization from incompatible pointer type
-o OBJ.i686-pc-linux-gnu/write_nat.o -c write_nat.c
write_nat.c: In function `V2_write_line_nat':
write_nat.c:103: warning: `line' might be used uninitialized in this function
write_nat.c:103: warning: `area' might be used uninitialized in this function
write_nat.c: In function `V2_delete_line_nat':
write_nat.c:613: warning: passing arg 1 of `G_malloc' as signed due to prototype
write_nat.c:497: warning: `type' might be used uninitialized in this function
write_nat.c:497: warning: `first' might be used uninitialized in this function
write_nat.c:498: warning: `Line' might be used uninitialized in this function
write_nat.c:502: warning: `n_adjacent' might be used uninitialized in this function
gcc -shared -o /usr/src/grass/grass51/dist.i686-pc-linux-gnu/lib/libgrass_vect.5.7.cvs.so -Wl,--export-dynamic -L/usr/src/grass/grass51/dist.i686-pc-linux-gnu/lib OBJ.i686-pc-linux-gnu/area.o OBJ.i686-pc-linux-gnu/array.o OBJ.i686-pc-linux-gnu/box.o OBJ.i686-pc-linux-gnu/break_lines.o OBJ.i686-pc-linux-gnu/break_polygons.o OBJ.i686-pc-linux-gnu/bridges.o OBJ.i686-pc-linux-gnu/buffer.o OBJ.i686-pc-linux-gnu/build.o OBJ.i686-pc-linux-gnu/build_nat.o OBJ.i686-pc-linux-gnu/build_ogr.o OBJ.i686-pc-linux-gnu/cats.o OBJ.i686-pc-linux-gnu/cindex.o OBJ.i686-pc-linux-gnu/clean_nodes.o OBJ.i686-pc-linux-gnu/close.o OBJ.i686-pc-linux-gnu/close_nat.o OBJ.i686-pc-linux-gnu/close_ogr.o OBJ.i686-pc-linux-gnu/constraint.o OBJ.i686-pc-linux-gnu/dangles.o OBJ.i686-pc-linux-gnu/error.o OBJ.i686-pc-linux-gnu/field.o OBJ.i686-pc-linux-gnu/find.o OBJ.i686-pc-linux-gnu/graph.o OBJ.i686-pc-linux-gnu/header.o OBJ.i686-pc-linux-gnu/hist.o OBJ.i686-pc-linux-gnu/init_head.o OBJ.i686-pc-linux-gnu/intersect.o OBJ.i686-pc-linux-gnu/legal_vname.o OBJ.i686-pc-linux-gnu/level.o OBJ.i686-pc-linux-gnu/level_two.o OBJ.i686-pc-linux-gnu/line.o OBJ.i686-pc-linux-gnu/list.o OBJ.i686-pc-linux-gnu/map.o OBJ.i686-pc-linux-gnu/net.o OBJ.i686-pc-linux-gnu/open.o OBJ.i686-pc-linux-gnu/open_nat.o OBJ.i686-pc-linux-gnu/open_ogr.o OBJ.i686-pc-linux-gnu/overlap.o OBJ.i686-pc-linux-gnu/overlay.o OBJ.i686-pc-linux-gnu/poly.o OBJ.i686-pc-linux-gnu/read.o OBJ.i686-pc-linux-gnu/read_nat.o OBJ.i686-pc-linux-gnu/read_ogr.o OBJ.i686-pc-linux-gnu/remove_areas.o OBJ.i686-pc-linux-gnu/remove_duplicates.o OBJ.i686-pc-linux-gnu/rewind.o OBJ.i686-pc-linux-gnu/rewind_nat.o OBJ.i686-pc-linux-gnu/rewind_ogr.o OBJ.i686-pc-linux-gnu/select.o OBJ.i686-pc-linux-gnu/sindex.o OBJ.i686-pc-linux-gnu/snap.o OBJ.i686-pc-linux-gnu/tin.o OBJ.i686-pc-linux-gnu/type.o OBJ.i686-pc-linux-gnu/window.o OBJ.i686-pc-linux-gnu/write.o OBJ.i686-pc-linux-gnu/write_nat.o -lgrass_gis -lgrass_datetime -lz -lgrass_dig2 -lgrass_dgl -lgrass_rtree -lgrass_linkm -lgrass_dbmiclient -lgrass_dbmibase && ln -sf libgrass_vect.5.7.cvs.so /usr/src/grass/grass51/dist.i686-pc-linux-gnu/lib/libgrass_vect.so
How does it look?
Jachym
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://www.fle.czu.cz/~jachym/gnupg_public_key/
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20041129/e67452f4/attachment.bin
