[GRASS5] v.out.ascii: Segmentation fault
Jachym Cepicky jachym.cepicky at centrum.cz
Mon Nov 29 11:18:03 EST 2004
One more thing:
On Thu, Nov 25, 2004 at 02:01:21PM +0100, Markus Neteler wrote:
> On Thu, Nov 25, 2004 at 01:45:00PM +0100, Jachym Cepicky wrote:
> > GRASS 5.7.cvs:~ > strace v.out.ascii novy
> > execve("/usr/local/grass-5.7.cvs/bin/v.out.ascii", ["v.out.ascii", "novy"], [/* 32 vars */]) = 0
> > uname({sys="Linux", node="trava", ...}) = 0
> > brk(0)                                  = 0x804b000
> > old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40017000
> > access("/etc/ld.so.nohwcap", F_OK)      = -1 ENOENT (No such file or directory)
> > open("/etc/ld.so.preload", O_RDONLY)    = -1 ENOENT (No such file or directory)
> > open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/cmov/libgrass_vect.so", O_RDONLY) = -1 ENOENT (No such file or directory)
> > stat64("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/cmov", 0xbffff058) = -1 ENOENT (No such file or directory)
> > open("/usr/local/grass-5.7.cvs/lib/tls/i686/mmx/libgrass_vect.so", O_RDONLY) = -1 ENOENT (No such file or directory)
> There is something wrong. The library should go into
>  /usr/local/grass-5.7.cvs/lib/libgrass_vect.so
GRASS 5.7.cvs:~ > locate libgrass_vect.so
/usr/src/grass/grass51/dist.i686-pc-linux-gnu/lib/libgrass_vect.so
GRASS 5.7.cvs:~ >
Don't know, if it helps
Jachym
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://www.fle.czu.cz/~jachym/gnupg_public_key/
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20041129/3def5660/attachment.bin
