[GRASS5] [bug #2738] (grass) make error in 57.cvs (cvs update on 11.29.2004)
William K
woklist at charter.net
Mon Nov 29 11:48:37 EST 2004
Markus-
I figured this one out and responded to another thread that mentioned
this problem. It seems that the Makefile says on line 324:
@ cp -rpf demolocation/ ${ARCH_DISTDIR}/
which (on Mac OS X at least) tries to copy just the contents of
demolocation to ARCH_DISTDIR instead of demolocation and its contents
(so I end up with ARCH_DISTDIR/PERMANENT/ instead of
ARCH_DISTDIR/demolocation/PERMANENT/). Then the .grassrc57 setup
fails. Remove the trailing slash from demolocation and it works:
@ cp -rpf demolocation ${ARCH_DISTDIR}/
PS. since Radim changed .grassrc57 to .grassrc6, shouldn't it be
changed here too (at least for consistency)?
On Nov 29, 2004, at 10:32 AM, Markus Neteler via RT wrote:
> Did you run
> make mixclean
> before compiling? May be needed this time due to significant
> changes.
> Markus
> -------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
William Kyngesburye <kyngchaos at charter.net>
http://webpages.charter.net/kyngchaos/
"This is a question about the past, is it? ... How can I tell that the
past isn't a fiction designed to account for the discrepancy between my
immediate physical sensations and my state of mind?"
- The Ruler of the Universe
